What airlid for 90mm TB
Do I need to go with a larger airlid for a 90mm TB setup? The car has the L92 heads and L76 intake with an LS2 90mm TB. What lid would work best? Would a custom cold air or ramair intake setup be possible with better results? Or would the time, price and hassle outweigh the gains in the end. Post away, thanks
Mitchell
Mitchell
ALL lids have a 90mm throat.....ALL lids have a 90mm inside diameter.......
lets repeat ALL lids(including stock)have a 90mm opening.Pick one it doesnt matter.And if you have any doubts go measure it..
90mm is the same as 3.54 inches if you dont have a mm scale.
