View Poll Results: LS7 vs L92 stroker vs L92 heads L76 intake on C6
LS7 block-L92 heads-L76 intake
40.91%
L92 stroker-L92 heads-L76 intake
36.36%
L92 heads-L76 intake-Cam on factory LS2
27.27%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
LS7 vs L92 stroker install on a C6
Old 03-12-2007, 06:34 AM
oscarav098's Avatar
Question LS7 vs L92 stroker install on a C6
Hello all,
First off let say this forum is a great source of info. Forum members seem to be very knowledgeable and courteous.
I've got the itch to mod my car. I have a 06 corvette, Z51 6spd, and I've been thinking about these options:
1 - cheapest - L92 heads, L76 intake and Cam.
2 - medium - L92 heads, L76 intake and L92 stroker.
3 - expensive - L92 heads, L76 intake and LS7 block.
All I've done to the car so far is long tube headers, dynatechs.
I like the idea of having crazy torque down low hence the idea of going LS7. I know the L92 stroker is a good value, 418 CID. Option number 1 is about half the cost of the other 2 so it wouldn't be as painful on the wallet. But i keep thinking if I'm going to do this might as well go all the way. If I go the stroker or LS7 I'm assuming dropping in either one should be fairly painless.
Are there any other options you guys recommend? shops in Dallas TX? Feel free to PM or email me.
Old 03-12-2007, 07:01 AM
Quickin's Avatar
Originally Posted by oscarav098
Hello all,
An LS2 416ci with L92 heads and L76 intake from the right builder will ***-rape a stock crate LS7. They're making 530 RWHP and over 500 RWTQ. A crate LS7 doesn't come close to either of those numbers for RWHP/RWTQ.
If you want the most power of the 3 choices....choose #2 and go with an LS2 block (416ci...if you want a 427ci LS2 it'll just make X amount more power than the 416ci), L92 heads and L76 intake. And it'll be a helluva lot cheaper than a LS7 set-up.
Old 03-12-2007, 07:08 AM
WKMCD's Avatar
It's going to take an L92 block stroker to get 416/418CI.
Old 03-12-2007, 07:20 AM
Quickin's Avatar
Thought he told me he used an LS2 block, maybe it was L92 than.
Old 03-12-2007, 08:40 AM
oscarav098's Avatar
Sorry guys,
I meant a short block LS7 not a crate LS7
Old 03-12-2007, 01:15 PM
fastGBcamaro's Avatar
Default Ls2
You don't have to use an L92 block to get 418 ci's. Im building a 412 ci LS2 using a 4.1'' stroke and the stock 4.00'' bore, but if I bored the block .030'' which is the max an LS2 should be bored to it would be a 418 ci.
Old 03-12-2007, 02:47 PM
11 Bravo's Avatar
Hello all,
If money is a non-issue then there's no replacement for displacement.
Old 03-12-2007, 07:20 PM
valdeztke's Avatar
Old 03-12-2007, 08:41 PM
VortechC5's Avatar
I am doing the LS7 block based 427 with ported L92s and the L76. It cost me about $1k more that to do this over a 416. I just received the shortblock so I don't have any results yet.
Old 03-12-2007, 08:42 PM
valdeztke's Avatar
What did it cost you all together?
Old 03-12-2007, 08:57 PM
VortechC5's Avatar
I have about $7600 -$7700 shipped for the shortblock, cam, timing chain, gaskets, rockers, intake, harnesses (knock, LS1 to LS2 TB, cam sensor, MAP), oil pump, ARP head bolts, etc., and another $1860 shipped for the Livernios stage 2 L92s.
Old 03-12-2007, 09:47 PM
valdeztke's Avatar
I was quoted 13201 for a 440 LS7 block w/ LS7 heads w/ all the needed stuff to go along. I just wanted to see how much you actually saved by going the L92 route over the LS7 heads route.
Old 03-12-2007, 10:53 PM
Quickin's Avatar
Head shop in Lauderdale sells those heads for $1,500, 100% complete ready to bolt on and he hand ports them to flow mid 360'scfm. I guess bigger shops have that over-head to pay for.
Old 03-13-2007, 01:12 PM
Stang's Bane's Avatar
Actually not that bad of a deal. Stock valves on the LS7 heads?? If so, stay away from a real aggresive cam.
Old 03-13-2007, 01:21 PM
oscarav098's Avatar
Thanks for your replies. Even though option 3 lost, I've decide to go with it. After much deliberation this one made sense for my wallet.
I am getting the ported L92 heads to help out a little so we'll see what happens. As soon as I get the car back I'll post some results just in case somebody is thinking about doing this.
Wish me luck.
Old 03-13-2007, 01:37 PM
valdeztke's Avatar
440 Cubic Inch LS7 Shortblock 1.00 $6,899.00
GM LS7 CNC Cylinder Heads 2.00 $2,598.00
Dual Valve Spring kit Rated to .650 lift 1.00 $299.00
Custom Camshaft 1.00 $389.00
Cometic LS7 Head Gaskets 1.00 $159.00
GM LS7 Head Bolts 1.00 $68.99
GM LS7 Intake Rockers 8.00 $71.60
GM Rocker Stands/bolts 1.00 $28.00
LS2 Ported Oil Pump 1.00 $00
GM LS7 Timing Set 1.00 $159.00
Cam Retainer Plate/Misc covers/Gaskets/fittings/sensors 1.00 $459.00
GM LS7 Intake 1.00 $300.00
GM LS7 Injectors 1.00 $389.00
Katech fuel rail spacer kit for LS7 injectors 1.00 $89.00
Assembly of shortblock to longblock 4.00hrs $360.00
Old 03-13-2007, 01:39 PM
NoGamesLS1's Avatar
Go LSX or Warhawk
Old 03-13-2007, 01:44 PM
NoGamesLS1's Avatar
^^^^I take that back^^^^
Check out a&a corvette https://www.aandacorvette.com/cart/s...p?MainCatID=11
A guy in town has one of their 441CID C5R based strokers and that thing is WICKED He put me to shame on the freeway and Im putting down ~510rwhp and ~480rwtq. And I believe that his cam is in the 224* range because it will pass smog. All I can say is if I had the money...
Old 03-13-2007, 01:56 PM
What cam??
Old 03-13-2007, 06:27 PM
Quickin's Avatar
You're right, just spoke to him, it was an L92 block
Quick Reply: LS7 vs L92 stroker install on a C6
