carbed timing
Old 03-12-2007, 08:40 AM
Darracq's Avatar
Default carbed timing
Has anyone had any spark knock with the msd curve, The fi only use around 30 total i belived, i am getting knock but my carb is lean, i dont see how it is so lean with 72 jets in front and 78s in rear on a 750 vac.
Old 03-12-2007, 09:24 AM
Vcious04's Avatar
Man, be very carefull with the msd setup. I found out the other day that I was probably on the edge of blowing something up due to the factory timing on the box. What happends is the map sensor automatically adds 6-7 deg of timing untop of your mechanical curve. I was accidentatly running 44-46 deg of total timing this whole time. I basically just disabled the map sensor and am running a custom mechanical advance (like the old days of mech advance only dist).
I am running 75 front and 78 in the rear and it was a little lean. I am going back to the dyno now that I got my timing issues worked out and re-tune it.
Old 03-12-2007, 09:35 AM
Darracq's Avatar
I dont have the map sensor hooked up it says optional.
Old 03-12-2007, 11:24 AM
91redchevy's Avatar
So far on my LS6 i haven't noticed any knock. I am running the edelbrock ignition setup
with the #3 pill. I don't understand why y'all are running lean, with the 625 road demon
i had to reduce my IFR's and IAB's cause i was running extremely rich at idle and cruise.
Now i have it pretty much dialed in 14.4-.7 @idle, 13.9-14.4@cruise, 12.8-13.3@WOT,
this is with 70's up front and 78's in rear. What kind of vacuum #'s are you pulling at idle
and WOT? You may have to change your power valve to a looser one if you are pulling
a lot of vacuum.
Old 03-12-2007, 11:54 AM
Darracq's Avatar
Not sure if my gauge is right or not but i think i had 21 at idle. I have a new 8.5pv
Old 03-12-2007, 02:51 PM
Darracq's Avatar
I closed the secondaries some and richened up the idle a little and there is no more pining but it is a little rich now.
Old 03-12-2007, 03:20 PM
91redchevy's Avatar
I'm running a 10.5 now that I leaned out my idle and cruise to where I want it. Seems to
work just right with my setup.
Old 03-13-2007, 07:32 PM
Darracq's Avatar
anyone know if there is a built in rev limit with the plug in pill, my car is breaking up real bad at around 5500 but tach could be off i guess, it runs great up to there, plugs are black except some of the ground strap looks pretty clean.
Old 03-13-2007, 08:18 PM
hpmotorsports's Avatar
Default timing
i built my own ignition system for my carb 5.3ls and set the timing in 200 rpm steps with max advance 36* using a stock computer and efi live to set advance works really great, i don't know much about the msd box , but i know that carbs like more advance than efi .
Old 03-15-2007, 03:58 PM
6L.IROC-Z's Avatar
There is a total timing limit that can be set on the msd box with the tuning software.My limit is set at 38*total, I dynoed mine this weekend and mad 20 more horse by cutting back my timming to 32*
Old 03-15-2007, 08:32 PM
Darracq's Avatar
cool. Did you try any lower,
Old 03-16-2007, 08:07 AM
s10-den's Avatar
Are you carbed guys running a distributor?
Old 03-16-2007, 09:44 AM
Darracq's Avatar
No,Just a programable msd box that fires the coils.
Old 03-16-2007, 03:27 PM
6L.IROC-Z's Avatar
At 29* it made 4hp less than 32*
Old 03-16-2007, 03:39 PM
Darracq's Avatar
I just set mine up for 32 all in by 2500, runs real good, still breaks up at around 5600 or so, i guess my valve springs are weak, it does show my tach off by a little but only 100 rpm or so, but it is hard to watch when i get on it. going to try and go to the track tomarrow.
Old 03-16-2007, 04:07 PM
6L.IROC-Z's Avatar
What cam and valve springs are you running?
Old 03-17-2007, 11:18 AM
Darracq's Avatar
Stock
Old 03-18-2007, 07:57 PM
s10-den's Avatar
You carb guys see where they put the hei in the ls1?
Old 03-18-2007, 08:17 PM
Darracq's Avatar
I saw somewhere they put a distrubtor in one, dont think it was a hei though,
Old 03-18-2007, 10:46 PM
s10-den's Avatar
yea.it was a HEI.Ill have to find my book again,it used a ford drive gear on the distributor,dont ask me why......lol
Quick Reply: carbed timing
