ARP Head Stud will not come out?!?!?
I have one ARP Head Stud that will not come out... all the others come out by hand using an allen wrench.
Any ideas/suggestions?
Is the special tool made to remove head studs that have seized???
You can try putting two nuts on the stud and tighten them together. Then using a wrench on the lower nut and turning it the top nut will keep it from loosing and the stud should turn. Good Luck
Thanks...
That will work for sure....Let us know Scott
Tony
Try this, Knurl grip stud extractor ,scroll down the page and you'll see it. This is what i used.
http://www.mcmaster.com/ctlg/DisplCt...lip&ToolsetAct=
Thanks everyone... if the double nut ( ) trick does not do it I will grab the Knurl-Grip Stud Extractor from McMaster...
FYI, I also found it at JEGS:
http://www.jegs.com/webapp/wcs/store...0002_751012_-1
