Installed LS6 Intake Yesterday
Everything went smooth. I found out the hard way that you need to remove the plastic clips from the knock-sensor wires...they kept the manifold from seating all the way on the heads.
I got in a hurry and wound up launching one of the clips into the intake port of the drivers side head. It fell into a port with the valve OPEN!
I was soooo lucky...I was able to turn the motor over with a wrench until the valve closed and then used a coat hanger to slide the plastic clip out. The instant I touched it, it fell onto the valve.
After that incident, everything went well and I didn't even break the oil pressure sending unit.
JC
JC
congrats, I recently installed a ls6 intake as well. Im glad you were able to get that plastic clip out of the head. I was able to keep the clips on, but I also hammered a little on the coolant lines to get them to sit lower. Good job on not breaking the oil pressure sending unit and enjoy the new extra power
Wow thats lucky you got that clip out, i was in too much of a hurry when i took out my old intake that i broke the oil pressure sending unit. You will definatly love that new found power, i sure did!!
I drove the car last night. It was a decent SOTP improvement int he top end. I can tell the PCM is still learning a little.
I also noticed the exhaust note was slightly deeper and more throaty at WOT.
Definitely worthwhile, especially since the cam is going in soon!
