Yanking out the EGR & AIR, what to do with wire?
I've read all the stickies and searched and nobody says what they do with the wire leftover the plugs into each of the little motors. I'm less concerned with the AIR pump down in front of the driver headlight compartment and more concerned with the EGR wire in front of the pass side head. Tape it up & stick it where? Cut it off somewhere? I know I'll throw a code too, I'll get it tuned out later.
I just traced mine back and cut them off. It really neatened up the engine bay. If you can trace them back and tape them up behind the manifold you may want to do that to get them out of the way.
