3 wire to 5 wire maf wiring diagram?
Old 03-12-2007, 11:34 AM
Ratical's Avatar
Default 3 wire to 5 wire maf wiring diagram?
I am trying to use an 05 GTO maf with my 98 wiring harness. Does anyone know where I can find a wiring diagram? I tried search, but couldn't find any matches.
Thanks,
Gary
Old 03-12-2007, 01:13 PM
ChrisS@sdpc's Avatar
Here are some details:
Code:
1998 F-body
Pin	Wire Color	Circuit No.	     Function
A	YEL	             492	     Mass Air Flow (MAF) Sensor Signal
B	BLK/WHT	             451	     Ground
C	PNK	             539	     Ignition Feed
2001 Vette
A	PPL	             719	    Low Reference
B	TAN	             472	    IAT Sensor Signal
C	BLK/WHT	             451	    Ground
D	PNK	             339	    Ignition Feed
E	YEL	             492	    Mass Air Flow (MAF) Sensor - Signal
2005 GTO
A	BK	             2759	      Low Reference
B	BK	             472	      IAT Sensor Signal
C	BK/RD	             450	      Sensor Ground
D	PK	             439	      Sensor Voltage Supply
E	BN/WH	             492	      MAF Sensor Signal
Attached Thumbnails 3 wire to 5 wire maf wiring diagram?-2005_gto_maf.gif   3 wire to 5 wire maf wiring diagram?-2001_vette_maf.gif   3 wire to 5 wire maf wiring diagram?-98_fbody_maf.gif
Old 03-12-2007, 02:06 PM
ringram's Avatar
Nice info dude
Old 03-13-2007, 10:38 AM
Ratical's Avatar
Thank you.
Old 03-13-2007, 04:52 PM
Phoenix383's Avatar
That is perfect man THANKS!
Old 03-13-2007, 04:57 PM
NemeSS's Avatar
i have an engine that came with what looks to be a 85mm maf
it has a an alum. end and a composite end. with a delphi logo
and 5 pins, can i use it on a 02 fbody?
sorry to hijack thread
Old 03-13-2007, 05:40 PM
NemeSS's Avatar
^has part# 25168491 on composite end
Old 11-07-2012, 04:49 PM
Chad17's Avatar
Im also doing something similar, wiring a 2010 camaro meter into my 98, can anyone verify the wiring schematics for the 2010 sensor?
Quick Reply: 3 wire to 5 wire maf wiring diagram?
