rotor install ?
Old 03-12-2007, 05:47 PM
Darbadocious's Avatar
Default rotor install ?
i just installed new rotors and my pads are rubbing. is there something i missed like resetting the pads or something. i just pulled the two bolts holding the caliper, pulled the caliper and reassembled with the new parts.
Old 03-12-2007, 06:32 PM
z28bryan's Avatar
When you say rubbing, do you mean they are touching the rotor with no stopping force? That's normal.
Did you clean and regrease the caliper pins though? Sometimes they get seized in some peoples' cars if ignored.
Old 03-12-2007, 07:03 PM
Trunion King
bene's Avatar
The reason why the pads are rubbing, you have to push them all the way back inside the caliper w/ a clamp. I just did my brakes (pads/rotors/brake fluid).
Old 03-12-2007, 08:56 PM
ok i just pushed back the pads with a clamp and opened up the bleed valve while doing it and everything is good. they're still touching but just barely, i guess it's allowable. thanks guys.
Old 03-12-2007, 09:29 PM
Copy & Paste Moderator
VIP1's Avatar
You didn't need to open the bleeder valve, but since you did, you now need to bleed the system.
Old 03-12-2007, 09:39 PM
i made sure not to let any air in, also kept presure on the clamps, and only let out about 10 drops.
Old 03-12-2007, 10:22 PM
Trunion King
bene's Avatar
Who told you to do that? That's a first time I've heard of having to touch the bleeder just to clamp down the pads. That's weird.
Old 03-12-2007, 11:34 PM
Flawless02SS's Avatar
Its very important to OPEN THE BLEEDER WHEN PUSHING THE CALIPER PISTON BACK IN. If you dont open it, you push old, dirty fluid back into your brake system. This is a BIG no,no for your ABS!!!!
Old 03-12-2007, 11:38 PM
And after doing so, there is no need to bleed the system. Just open the bleeder press the pad (piston) back in and close the bleeder while the clamp is still on the old pad.
Old 03-13-2007, 12:14 AM
Trunion King
bene's Avatar
But he wasn't changing his fluid. He was just changing the rotors.
Old 03-13-2007, 12:16 AM
boondiggys's Avatar
the brakes use a sealed fluid system
Quick Reply: rotor install ?
