Door Unlock problem
Old 03-12-2007, 05:56 PM
99PewterT/A's Avatar
Default Door Unlock problem
I have searched and couldnt find the answer to my problem. When i bought my TA it had an Avital remote start and wouldnt unlock from the remote start remote or by pushing a button inside wheather the car was on or off. I figured it was the wiring but i just had a new alarm installed and they re-did all the wiring and still the same problem. It cant be the wiring becuase i can hear the relays they installed click and its not the "waking up" of the BCM issue becuase it doesnt work when on either. However i can lock it from the remote or switches just fine. This is driving me nuts. Help!
Old 03-12-2007, 09:46 PM
Anyone? Im thinking maybe the actuators?
Old 03-13-2007, 12:10 AM
01WS6/tamu's Avatar
If it locks w the factory lock switch it is not the actuators. If the switch does not work it is possible.
Old 03-13-2007, 07:52 AM
Well they do lock when the switch is pressed but then again when the switch is pressed it also triggers the re-lays to unlock it as well but it just wont unlock. Its weird.
