broke spark plug in motor...need advice
Old 03-12-2007, 10:04 PM
nofxrxmxpx's Avatar
Default broke spark plug in motor...need advice
i bought a motor... it has some bosh +4 bullshit in it.. i was putting the long tubes on it so i took the plugs out (was changing them anyways) and one of the plugs is completly stripped of the electode and the 4 tabs.... i am going to compression test it by hand tomorow, if it checks out ok is there any methods i can use before i go tearing the whole motor down? any help would be awsome, thanks guys
Old 03-12-2007, 10:08 PM
nofxrxmxpx's Avatar
my swap is so close to being complete too
Old 03-12-2007, 10:32 PM
StickSS's Avatar
HI: Nice looking ride. See if you can turn the engine over freely a couple of tiimes with a socket and breaker bar on the pully. see If it turns freely, if it gets tight stop and dont't turn it over anymore. You couldtry a small probe in the spark plug hole if it only goes down a few inches the piston is probably intact. If the probe goes all the way into the oil pan then you know the piston is bad. Same thing happened to me a psiton let goe and the electrode got smashed. The rod jammed into the cylinder wall and the engine wouldn't turn freely. Post up a picture of the bad plug maybe some one can tell if it has engine damage. Good Luck
Old 03-12-2007, 10:45 PM
nofxrxmxpx's Avatar
here are the pics...
sorry they are so big..
Old 03-12-2007, 10:52 PM
nofxrxmxpx's Avatar
it almost looks melted to me... idk im so worried.
Old 03-12-2007, 11:08 PM
nofxrxmxpx's Avatar
i just went in the garage and with a dipstick in the hole on the piston, i turned the crank by hand and it pushed the dipstick out and back in with minimal effort... now on to the compression test tomorow..
Old 03-13-2007, 02:16 AM
nofxrxmxpx's Avatar
anyone have any ideas?
what does the plug look like to yall
Old 03-19-2007, 10:44 AM
98ws61le's Avatar
update?
Old 03-19-2007, 11:29 AM
skifast87's Avatar
I guess do a compression test. it almost looks melted to me also. Just turn that motor over nice and slow a few more times first to be sure. I broke a plug off in side a ford contour once that sucked. I vacuumed out the cylinder and turned it over very very slow to be sure i had it all.
