Gears & Axles - driveshaft reinstall question
View Full Version : driveshaft reinstall question
brad8266
03-12-2007, 10:32 PM
I put marks on it when i took it off so that i would put it on the same way after i was done but the marks mysteriously dissapeared. I just put the driveshaft back in anyway, so if it is in the oppositie way will it make a difference in balancing or will it be fine?
bigdsz
03-12-2007, 11:16 PM
Obviously you have a 50% chance of getting it back where it was. Should you have vibration, which is unlikely, just rotate it 180*. From the factory they are not balanced with any other part of the drivetrain.
brad8266
03-13-2007, 01:49 PM
Thanks, i didnt think they came balanced.
02NBMWS6
03-14-2007, 01:27 AM
ive had mine in and out so many times, and ive never marked it. it should be good man
00BlueTA
03-16-2007, 12:43 AM
When they balance the drive shaft they do it form the yoke to the u-joint. It doesnt matter if you just took the drive shaft out and put it back in, that changes nothing.
