Suspension & Brakes - coil over kit
Ws6reaper
03-13-2007, 03:13 AM
does anyone make a reasonably priced adjustable coil over kit for 98+ F Bods?
YellowToy/A
03-13-2007, 08:17 AM
You can get ground control set up at the WS6store---> 380.00 I think
You have to know the rates you want. 300 lb/in is stock. I have 400 ib/in with a 3/4 in drop. You should get new shocks to go with. Koni work well.
Ws6reaper
03-13-2007, 08:17 PM
thanks, are they hard to install? What spring rate should I get? I want my car to sit low, without riding terribly rough.
RAMPANT
03-13-2007, 08:38 PM
I have the GC kit on my car. I'm quite happy with it. I have Koni SA's too which I think make it more firm than my springs. My fronts are 500# and the rears are 150# straight rate springs. Mine is set up for autocross not so much street, but Sam could certainly help you selected the best for you.
I got my springs and GC kit from Sam Strano >>>>>>>>>>>>>>>>>
I change my rear ride height every time I go to the drag strip to help clearance my 27" tires, then lower it to drive on the street.
Good luck.
Ws6reaper
03-15-2007, 05:27 PM
Thanks RAMPANT, Ill be giving him a call then.
YellowToy/A
03-16-2007, 01:02 PM
Hard to install is relative. It was not hard for me, but I have heard that only a someone who who is a install god can do it. The lower u go the more rate u need. If you go with more than stock rate you should get konis to dampen the springs. Most shock do not work well with high rate springs.
z28bryan
03-16-2007, 01:56 PM
Could Strano springs be tossed on GC coilover perches, in the event that I would possibly want to raise the height slightly? :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
