Intake Manifold suggestions?
Old 03-13-2007, 10:24 AM
bigbipo's Avatar
Default Intake Manifold suggestions?
Looking for some feedback on what it takes to throw a 90/90mm ls2 intake on?
Or
Is it better to stick with a LS6 intake?(80/80)
I'v already located a t/b that will work for the ls2 that uses a throttle cable instead of drive by wire..
My main consern is,
ls6 a better intake over the ls2 intake, or is the ls2 a better op then spending the big bux on a FAST 90/90
Also will fuel rails, injectors, ect work on the ls2 like they do for a ls6
HEADS = 243(ls6)
Old 03-14-2007, 04:20 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Go LS6 if you are just looking to keep your car a bolt on.
Go FAST 90 if you have the money and atleast have a cam etc...although people do go the 90 route with bolt ons.
The LS2's flow is pretty shitty last I remember.
Old 03-14-2007, 07:03 PM
Luna's Avatar
Like lithium said an LS6 intake outflows an LS2 and it takes alot more to make the LS2 manifold work (I believe the fuel rails don't bolt right up.) If your looking to go with a H/C setup a fast 90/90 setup may be a good investment.
But if its a bolton car a LS6 intake and ported stock throttle body will work great
Old 03-14-2007, 07:06 PM
j99fbody's Avatar
I have the ls2 on my car and its not worth the trouble, wish i would have bought a fast 90
Old 03-14-2007, 07:10 PM
5_02ls1's Avatar
i used the weiand. its an alumionum version of the ls6.it has an acces panel on the bottom for porting.and the opening can be ported to match the 60mm t/b.it looks good and resonably priced
Old 03-14-2007, 07:13 PM
Luna's Avatar
60mm TB? I hope not... stock is what like 74mm?
Old 03-14-2007, 07:16 PM
5_02ls1's Avatar
Default my bad 80 mm
lol my bad 80mm
Old 03-14-2007, 07:37 PM
Boodyrider's Avatar
Or if you want to get serious...
Carb manifold with sheet metal upper and a 90mm TB.
Old 03-15-2007, 11:47 PM
TERMINAL VELOCITY's Avatar
Ls6 and ported TB or Fast with Williams 90mm TB.
