Can't make up my mind on which exhaust
Old 03-13-2007, 02:03 PM
Pipelayaz's Avatar
Default Can't make up my mind on which exhaust
OK I been searching and researching for several weeks now on what exhaust setup I want and have made up my mind probably 10x over.
I'm crossed between two set-ups and if you guys could just put in your two cents I'd be very greatful.
1st Set-up:
Kooks 1 3/4 Headers - TSP ORX-pipe - Dynomax Bullet's, Sweet Thunder or something along those lines.
Pro's
-Sounds Great
-Best Performance
Con's
- Ground Clearence
- Cops (noise)
2nd Set-up:
Kooks 1 3/4 Headers - Kooks ORY-pipe - Keep Flowmasters till I can afford Corsa
Pro's
- Sounds alright
- Good performance
- Better ground clearence?
Con's
- Not the best Performance
- More Costs involved
- Doesn't sound as good as the x-pipe
These are my veiws. If you guys can talk me into one of the set-ups that'd be a great help! Thanks!
NOTE: I would also like to add that I would like to lower the car with Eibach and revalved Bilsteins or possably some coilovers. I haven't made up my mind on that one either. This car will be a Street/Strip as well.
Old 03-13-2007, 02:28 PM
SSpdDmon's Avatar
To me, it sounds like you want an all around performance car. When you're talking "lowered" and "strip" about the same car, it's a bit of a contradiction. As for the exhaust setup though, I'd go ORYP/catback if you really want to lower it. If you keep it off the ground, I'd say, "Consider true duals." But, I'd highly recommend riding in a car with true duals first if you can. There's a lot of interior noise with dumps at the axle and they can make for annoying situations (ie trying to have a conversation with someone, talking on the cell, etc.).
Personally, I'd go ORYP + Magnaflow. The Corsa's are known for having the internal baffle blow out causing them to sound rather $h!tty. Just my $0.02...
Old 03-13-2007, 02:29 PM
blackmagic2's Avatar
get true duals but extend all the way back and get some good mufflers (that will get rid of some clearance problems plus the noise)
Old 03-13-2007, 02:37 PM
Pipelayaz's Avatar
My buddy Tom has headers an X pipe with bullets on his ride and I've rode/driven it many times and I dig it, especially on cold starts. My car only gets driven maybe 1 or 2 days/50 miles a week at best. After Tom hit a dead racoon in the road and took off one of his bullets is when I started thinking more about the clearance issue. Later on I would plan to run the duals all the way back...
Thanks for the info on the Corsa... I never heard of that. I was thinking of Borla as well... I just like the Corsa tips more.
Old 03-13-2007, 02:39 PM
gollum's Avatar
Do you still have your OEM exhaust? KOOKS headers,No CATS, and your OEM aftercat system would be cool... TRUST ME!
Pipelayaz's Avatar
I may have to get a price quote on that... Not sure If any hick around here will custom fab one up for me. I may take a trip to Vengeance or something.
Old 03-13-2007, 02:41 PM
Pipelayaz's Avatar
Flowmaster cat-back that is all....
Old 03-13-2007, 02:46 PM
gollum's Avatar
Stick with your Flowmaster until you can find a good OEM. Heres my 1998 OEM WS6/SS exhaust
Attached Thumbnails Can't make up my mind on which exhaust-p1000243.jpg   Can't make up my mind on which exhaust-p1000266.jpg   Can't make up my mind on which exhaust-p1000259.jpg
Old 03-13-2007, 02:56 PM
SLPSS99's Avatar
Do the X-Pipe!!! In my opinion you cannot beat the sound, no Y-Pipe setup will sound as good as the TD, Remeber this is MY OPINION no haters please Like stated before get a good set of mufflers and it won't be that loud. I am lowered with a lanes TD setup and the only ground clearence I had is with big speed bumps and that was it, nothing came in contact when on reg roads.
Dan
Old 03-13-2007, 05:00 PM
TheLS1Kid's Avatar
True duals all the way!
Like SLPSS99 said, no y-pipe setup will sound as good as the true duals.
Theres also a gain in the performance area with them also.
Just make sure the pipes get tucked up high enough so ground clearance isnt a big issue. Flip your fuel lines if you have to.
Old 03-13-2007, 05:25 PM
BayAreaSS's Avatar
duals FTW!
I've had my x-pipe dumped with dynomax bullets for a about 2 months and i drive my car everyday. It doesnt bother me at all and it sounds great.
Old 03-13-2007, 10:19 PM
Pipelayaz's Avatar
Thanks for the comments guys...I'm getten good feedback.
I was thinking also... Dynomax Bullets - Sweet Thunder or Moroso Spiral Flows? I've heard a lot of good thing about Dynomax and a few good things about Sweet Thunder but nothing on Moroso Sprial Flows. Any word you guys hear on them?
Old 03-13-2007, 11:22 PM
BayAreaSS's Avatar
i will be getting rid of my dynomax bullets for some powersticks. I like sweet thunders a lot too!
Old 03-14-2007, 08:56 AM
gollum's Avatar
I found this quote from another tread
Originally Posted by W8S SS
I just put my eibach pro kit on yesterday. I recommend anyone with TSP true duals to think hard about the pro kit though, I have scraped everything since yesterday. It's mostly my turn downs that hang an inch off the ground.
Old 03-14-2007, 09:09 AM
Pipelayaz's Avatar
Maybe I should just keep stock ride hight until I mount the TD's to the rear.
Thanks for looking that up.
Pipelayaz's Avatar
I been pushing for Sweet Thunder Lately.
Old 03-14-2007, 09:32 AM
gollum's Avatar
SLP springs will work perfectly with true duals, they will lower your car no more than 3/4".
Here's another good tread:
https://ls1tech.com/forums/suspension-brakes/674797-lowering-car-tsp-true-duals.html
