WTF now i cant connect my hydraulic line!!!
Old 03-13-2007, 05:14 PM
C Murda's Avatar
Default WTF now i cant connect my hydraulic line!!!
ok so i got my new tranny in with the new Spec 3+ clutch and im going to connect the hydraulic line and it wont go in...
Old 03-13-2007, 05:16 PM
ls1 joe's Avatar
Which slave are you using? I have had customers in the past that the dealerships or parts store gave them the wrong one. Make sure they are the same as the old one.
Thanks,
Amber
Old 03-13-2007, 05:24 PM
C Murda's Avatar
well im using all my original part. everything was working fine when i pulled my old tranny out
Old 03-13-2007, 05:26 PM
C Murda's Avatar
oh and im not sure if this is supposed to happen but i cannot push my clutch pedal in at all either. the quick disconnect is disconnected dont know if that would be why but i cant get it connected anyways. it just wont go in
Old 03-13-2007, 06:10 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Crack the bleeder screw, then try it. And as you have seen, you should not be able to move the pedal at all with the fitting disconnected.
Old 03-13-2007, 06:22 PM
C Murda's Avatar
is there a way to release pressure from the slave cylinder? my problem is that the hose will not connect into the transmission. it wont go in far enough so that it will connect. could this be because of my new clutch? i have the spec 3+ and it came with a shim that i was supposed to use to shim the slave cylinder and i did so. now i have everything in and ready to go and i cant get that damne hydraulic line to go in far enough so it connects.
Old 03-13-2007, 06:31 PM
MeentSS02's Avatar
That's why I said to crack the bleeder screw (it is on the slave) and THEN try to connect it. That will relieve the pressure in the slave.
Old 03-13-2007, 06:36 PM
brad8266's Avatar
read the sticky here to see where the bleeder cracker is.
Old 03-13-2007, 07:00 PM
Dutchesscamaro's Avatar
Listen to Meentss02...You must relieve the slave.
Crack the bleeder, as difficult as it is to get to.
Otherwise it will never go in.
Bob
Old 03-13-2007, 07:10 PM
The PAT WS6's Avatar
crack the bleeder valve shove the bitch in there, and bleed the system
Old 03-13-2007, 07:25 PM
C Murda's Avatar
ok what do i use to crack it open?
Old 03-13-2007, 07:44 PM
C Murda's Avatar
anyone? just wanna get this done before it gets too cold out...
Old 03-13-2007, 08:31 PM
C Murda's Avatar
ok no need to respond i figured it out 7/16 socket....released some pressure and the line connected finally! thanks to all who helped. now to connect my exhaust and i have my car back after almost a year!
Old 03-13-2007, 09:57 PM
03 BUSA's Avatar
I had this issue before and this had worked. Usually I have a hard time getting the damn thing off, and I have the special tool for it.
Old 03-31-2007, 04:56 PM
SpdFrk1990's Avatar
Where did you get the tool at?
Old 04-01-2007, 06:29 PM
LS1Tech Sponsor
Slowhawk's Avatar
I've learned to plug in the slave right before tightening the tranny in.Makes it easier but we do have a special socket assembly to hit the bleeder if we have to.
Quick Reply: WTF now i cant connect my hydraulic line!!!
