98 PCM question
Old 03-13-2007, 08:47 PM
ez98ls1's Avatar
Question 98 PCM question
I have a 98 formula and was considering a h/c combo. Do I need to upgrade the PCM to a 01/02 to be able to better tune the car and if so where do you get one.
Thanks,
E
Old 03-13-2007, 08:59 PM
LS1TECH Sponsor
foff667's Avatar
You know its not as simple as just swapping out computers correct?
Old 03-13-2007, 11:08 PM
pkincy's Avatar
For tuning for a H/C car your 98 will be fine.
And remember that most folks that use EFILive have an unlimited license on the 97/98 stream so you should be able to find someone that can help pretty easily.
You can't do custom OSs but for a NA H/C car you shouldn't need one.
Perry
Old 03-14-2007, 04:15 PM
Redline-Motorsports's Avatar
Like pk says, you should be fine for a H/C car. To change to a 99+ system requires a gastank change, dash cluster and quite a few pins that need to be changed. Not worth the BS for what you are doing!
Old 03-14-2007, 05:07 PM
pkincy's Avatar
And now that Craig Moates has the RRer available for the 97/98 pcm there is even one less reason to change.
Mine arrived today.
Perry
Old 03-14-2007, 10:19 PM
Doc
Doc's Avatar
Not to sound like a total jackass but IMHO, the benefits of EFI Live's Custom Operating systems, and RTACS which are not currently availible to 98 users are a "worthwhile" reason to goto the "trouble" to upgrade a 97-98 vehicle.'
*Note the following statement has to be taken in consideration that the poster has taken mere McDonald Douglas/Boeing F/A-18's and "upgraded" them to be used by the US Navy's Flight Demonstration Squadron. They were perfectly good grey jets before...What do you want to drive?
Old 03-15-2007, 07:19 AM
slow's Avatar
I believe RTACS should work with the new 98 roadrunner. I haven't tested mine yet.
Ryan
Old 03-15-2007, 08:20 AM
pkincy's Avatar
I haven't tested mine either but it is here. The motor simply isn't ready yet.
Perry
Old 03-15-2007, 01:22 PM
Doc
Doc's Avatar
Please post up in this thread or over on the homesite. This is valuable info.
