4.8/5.3 vs 5.7/6.0 debate
Being a user who surfs the only the conversion part im wondering what engines are best for the money. I have seen quite a few 4.8/5.3 for pretty decent price and the ls1/6.0 not badly priced either. Just wondering who is running what motor ? any pros/cons ? Im going to be using the carb. set up and the motor is going either in my olds or possibly a 68 c10 pending the sale of the olds. Thanks for any input!
I really wanted an aluminum LS1 from an F-body but now I think I could have just used a 5.3 and saved some money. The all aluminum part is pretty cool though.
I have a 5.3. Bought it from a member here because the price was so cheap. I am using it for mock ups now in my 56 chevy sedan. I am saving for an all aluminum LS2 block. But I could still just use the 5.3 if I so desire (it is only .7 L away from a 6.0 )
The benefits of the LS2 is weight and the larger displacement. Plus it removes the limits of which heads and pistons you can run allowing you to change displacement at your whim like the Gen I was so famous for.
My .02
Mal
My .02
Mal
Either one is a good choice.. depending on what your expectation are !.. Daily Driver, Street/strip, racing, etc.. How much HP / TQ you are wanting to make it put out and what car/truck it i going into. I did my LS1/T56 into my 71 Chevelle, but I am thinking that for my 71 Nova.. I could get alway with a 5.3L and still be happy since the car is lighter than my Chevelle.
Either way.. you will not go wrong... just consider your end goal.
that is a good point. I am considering doing a 5.3 swap as well into my third gen firebird. The 5.3s are cheap and plentiful. While the stroke and bore are different from 5.7 and 6.0s, the block is the same. Therefore, heads, cams, intakes are all interchangeable. Swap on some flat top pistons and bump the compression ratio up to 10.5, mildly aggressive cam (LSA, say, 114), and LSX intake from a company like FAST and you'll be making 400+ HP/TQ in no time and you'll have spent less and have bragging rights.
Also, please note that this is my opinion. Not fact. Sure there are benefits to larger displacement, all aluminum block (even though the 5.3s can be had in all aluminum as well), but it may not be necessary for a DD. People will tell you that there is "no replacement for displacement" which is more or less true and that a 5.7 or6.0 has "more potential", but again, you have to consider your needs. Do you really need an engine capable of making 600 HP? Do you really need the
"potential" of making almost 1000HP with turbos and nitrous? If you intend for you vehicle to be a DD or regular "fun" car, probably not.
That's just my two cents.
a 5.3 has the same stoke as a 5.7 and 6.0 the only difference is bore size, i love 5.3 they are great and cheap,also make plenty of power, i built a 5.7 with 8.89cr ,cnc ported ls6 heads,590 cam,ls6 intake, long tubes, for a turbo car and he wanted to save up more money before he put the turbos on it,so we tuned it NA
it made 350rwhp, my 5.3 made 350rwhp small cam & 2.00 intake valves, 750 holley, so cubes are not that big of a deal
Thanks for the replies, that was pretty much the answers I was looking for. I was thinking that the 5.3 could be a little more cost efficient and still make the power i needed (300 - 500 range)
The 4.8 has a smaller stroke, and longer rods than the 5.3... The 5.3, 5.7, 6.0 all have the same 3.622" stroke, and 6.098" rods. Just different bore sizes make the difference.
The 4.8, and the 5.3 both have a 3.779" bore. So if all you had access to is 4.8's you can buy one, and use the crank and rods from a 5.3/5.7/6.0 and have yourself a 5.3! The 4.8 is DIRT cheap too... Even cheaper than the 5.3. If you want to build a performance 5.3, and plan on getting forged crank, rods, etc you might be better off buying a 4.8. You can pick them up for a couple hundred bucks all day long. That's what I'm doing, I paid $207.50 for my 4.8 (but then I had to ship it, but it's still dirt cheap becuase there is NO LSx engines ANYWHERE here).
I've read here, on LS1Tech, that you can safely bore the 5.3/4.8 block out to take the 5.7 pistons, and still have room to go up another size or two if you ever had to... You'd pretty much have an iron block LS1 by doing that. In fact a lot of guys that plan on pushing a lot of boost go this route because the iron block can handle it better... The weight difference is only ~60lbs from the aluminum to steel counterpart...
You do the math
You do the math
but i agree with the above about the vortec motors versus the car motors.
Originally Posted by patgizz
so YOU're the one i was cursing for outbidding me on that one!
If your looking at getting a 4.8 or a 6.0 for close to the same price and can afford it, get the 6.0L. That is a bigger diffrence in performance. Also if you want some great heads on a budget. The l92 heads are awsome but want fit on a 4.8L, 5.3L, or 5.7L because the valves are to big for the smaller bore engines. Now I would call that a big deal.
