Ackattack1
03-14-2007, 10:51 AM
does anyone have a scanner that will work with a 97 tahoe. Something like autotap or HP tuner.
I'm getting a random misfire code, and i'm trying to figure out whats causing it.
After doing some reading online, it can be caused by many things, so at this point I may have to clean/replace injectors or replace the catalytic converter. I'll probably also replace the rotor (did the plugs and dist. cap last night to no avail).
If it was around Bremerton, that would be great so I could get it quick, and get it back to you quick.
