pacesetters came damaged
Old 03-14-2007, 07:50 PM
ls1n00b's Avatar
Default pacesetters came damaged
Yea so my day got a little pissy after getting my pacesetters..the box they were in had a tear on the end and even the plastic was torn trough..should i send these back and complain to fed ex ********? or is it a easy small fix? im not sure..
http://i106.photobucket.com/albums/m...g?t=1173919651
Old 03-14-2007, 07:56 PM
BigKap94z's Avatar
Thats not really a big deal actually. Easy fix with some small taps from a hammer.
Old 03-14-2007, 07:57 PM
terr1bleone's Avatar
if your talking about that little crease dent on the end edge, id say compain to fedex. but you could easly tap that out.. or put a cresent wrench on there as tight as possible then just bend it back up a little.
Old 03-14-2007, 07:59 PM
ls1pwrdss's Avatar
cresent wrench is the fastest way to fix that
Old 03-14-2007, 08:06 PM
ls1n00b's Avatar
thanks guys, ill use the cresent wrench.i bet they just threw the package in there..
Old 03-14-2007, 08:07 PM
Tainted's Avatar
fix it and bitch to fed ex... I mean who DOESNT like bitching at the delivery guy?
Old 03-14-2007, 08:12 PM
BLK02TA's Avatar
I would just install them and be done with it. Spend the time you could have used bitching, on the install. It's not like its a big dent?
Old 03-14-2007, 08:21 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
EXACTLY MAN..C'MON.
Old 03-14-2007, 09:27 PM
5_02ls1's Avatar
just bend it out and put them on bitching is for wemon on the rag
Old 03-14-2007, 09:33 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Mine were the same if I remember...nothing a hammer could not fix.
Old 03-14-2007, 09:36 PM
2_wacko's Avatar
Both of mine came like that no problems here.
Old 03-15-2007, 09:59 AM
irnwkrjim's Avatar
The pair I ordered last fall came the exact same way. The damage was in the same exact spot. Just install and enjoy them.
Old 03-15-2007, 11:56 AM
cobrakiller221's Avatar
Mine came with a bigger flat spot than that. I just fixed it with channel locks and a rubber mallot. TSP told me that a muffler shop can put it in there expander and fix it.
