Those using nitrous jets for restrictors come in!
Old 03-15-2007, 12:46 PM
LS1Tech Sponsor
Superman09's Avatar
Default Those using nitrous jets for restrictors come in!
Just seeing where you guys are starting when choosing which jets to use to restrict oil feed for turbos. I am a twin set up and have too much oil going to the turbos. I'm going to use just 1 restrictor in the main feed line and have no idea what size to start with. Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-15-2007, 04:27 PM
Ping King's Avatar
with a restrictor keep in mind you most likely wont be seeing less pressure, youll probably be seeing less volume, so you may want to put the resrtictors at the begining of each turbo and keep an eye on your drain.
Old 03-15-2007, 08:53 PM
LS1Tech Sponsor
Superman09's Avatar
bump. So i should put a jet in front of each turbo then your saying? Or one i nthe feed off oil block spout? And what size should i start with? Thanks!
__________________
Old 03-15-2007, 09:01 PM
Ping King's Avatar
yea...dont put it in the feed block. Start big and go smaller. i run a .064 on my turbo
Old 03-15-2007, 09:05 PM
LS1Tech Sponsor
Superman09's Avatar
ok, ill put one in each turbo and start bigger around about .060 ish? Thanks!
__________________
Old 03-16-2007, 05:39 AM
LS1Tech Sponsor
Superman09's Avatar
Ok, i'll add some more info that may be useful.... My oil feed in -4 goes from the oil block thing above filter to a Tee just in front of drivers side turbo, then into the turbo, then the other side of the Tee has a -4 line going to the pass side turbo. Also these are journal bearing turbos, not DBB. This help a little more? Thanks!
__________________
Old 03-16-2007, 08:59 AM
6 Second Club Moderator
LASTLS1's Avatar
I think I use a 40 thou.
Old 03-16-2007, 09:56 AM
427's Avatar
I called Garrett on this subject years ago, they said to keep the turbo inlet between 5-30 psi during the whole rpm band. On my engine a .060 worked out good on the low side (above 5psi) but had a little to much high side (around 40psi @6500rpm). My truck now has over 60,000 miles on it with two different turbo's in that time. The one that broke was a overspeed problem (shaft sheared@ 25,000miles) not a oiling problem, the second one is still on it.
Kurt
Old 03-16-2007, 11:26 AM
LS1Tech Sponsor
Superman09's Avatar
so your saying i should use a .060 at each turbo or in the main feed line after oil block? Any way this could be too little oil and starve them or is that not possible? Thanks!
__________________
Old 03-16-2007, 11:41 AM
LASTLS1's Avatar
I use a 40 at each turbo. Are you ball bearing?
Old 03-16-2007, 11:55 AM
LS1Tech Sponsor
Superman09's Avatar
journal, i dont want to start too small and starve my turbos ya know? Just need to know of a refrence point to start that will be safe and if it'd be best to put the restrictors at each turbo or just 1 in the main feed. Gracias~!
__________________
Old 03-16-2007, 07:35 PM
LS1Tech Sponsor
Superman09's Avatar
anyone else?
__________________
Old 03-16-2007, 09:15 PM
427's Avatar
I would put one restrictor at each turbo, maybe start with a pair of .080 and see if it smokes. If it don't smoke run it!!
Kurt
Old 03-17-2007, 07:43 AM
LS1Tech Sponsor
Superman09's Avatar
ok thanks, i'll go with your advice since you guys will (Rich) will be tuning the car here real soon! Thanks!
__________________
Old 03-17-2007, 09:34 AM
Ping King's Avatar
yea..you would probably be safer starting at what kurt said. i was fine at .064 but if youre good at a higher number..stick with it.
Old 03-17-2007, 09:37 AM
LS1Tech Sponsor
Superman09's Avatar
Ok cool, thanks guys. See you soon Kurt!
__________________
Old 03-18-2007, 10:34 AM
LS1Tech Sponsor
Superman09's Avatar
What is the difference of putting the restrictor at the source (oil block) Vs. one at each turbo? How is each one different and what does each do differently? Trusted source Turbo Tech says it should be at the source, and W2W and a few others say to run it at the turbos like they personally do.... Is there a big difference? If so, what is it? Thanks!
__________________
Old 03-18-2007, 10:51 AM
bowtieman81's Avatar
I bought a function7 restrictor for my setup. I like it better than using a nitrous jet. I tried the nitrous jets, but they did not give me much confidence that it would not leak.
Old 03-18-2007, 11:25 AM
LS1Tech Sponsor
Superman09's Avatar
Ok, well im going to pick up some clear line to hook up as drain today so i can see what its doing to make sure its not the drain. If the drain is working good, then i'll try out a restrictor and hopefully can have it sorted out today. Thanks!
__________________
Old 03-18-2007, 11:29 AM
02SSLE's Avatar
I have a .80 and it is still a little to big still smokes some but I tried without it smoked alot. I did a search and come up with people using from 80 to 60 so I went with 80 to make sure I had enough oil.
Quick Reply: Those using nitrous jets for restrictors come in!
