Gears & Axles - Changing from 1350 to a 1310 (stock)
ZmyHPandrun
03-15-2007, 02:40 PM
Can anyone give me a quick rundown on what I need to do to get this changed? I bought the ds from a guy who used it with a 12 bolt and I need to convert it back for temporary use with a ten bolt. Thanks...
2001 Pewter WS6
03-16-2007, 03:02 PM
All you need to do is get a 1310 U-Joint from Advanced Auto Parts, they are cheap. The 1350 uses clips to hold it in. Get a 1310 that uses clips and you are good to go. You don't have to get it pressed out or in. Keep the U-Joint that is in it for when you eventually go to a 12bolt. That U-Joint cost $50. PM me if you have any questions...
WolfgangX
03-17-2007, 09:37 PM
The U-joints can be hard to remove, i had to get mine pressed on.
2001 Pewter WS6
03-18-2007, 09:31 PM
The stock one is hard to remove. This has a 1310/1350 Spicer in it, he just needs to remove 2 clips and he is in business.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
