Piston to Valve Clearance
Originally Posted by GuitsBoy
T-Rex, MS4, G5x4, FMS-15, texas giant. They all fit, as long as youre runningstock heads. Change anything on the heads or even te gasket, and all bets are off...
ouch!
So anyone know what can clear on a stock motor, with Trick Flow Heads?
w/ no milling?
Once you mess with the heads or gaskets you have to measure PTVC. Your best bet is to buy your heads/cam and when you install them flycut the piston tops when you do the swap.
since the TF heads change the valve angle...doesn't that increase the clearance on the valves??
or so i've heard.
so assuming stock gasket..you could run a bigger cam than you can on other heads...or possibly a thinner gasket.
but i think your question falls under the "if you have to ask..."
you may as well check to confirm
or so i've heard.
or so i've heard.
or so i've heard.
