Exhaust Hanger Part #
I was wondering if someone knew the part number for the Exhaust Pipe Hanger Bracket. I looked through my shop manual and all i was able to find was how to change the exhaust system rather than the hanger bracket part number. If you have an Exhaust system like the SLP Loudmouth its what holds up the piping that connect to the tips on the rear of the car. I guess when i went true dual i somehow lost the driver side one, and now that i want to continue the system out to the rear, i need that hanger.
-Joel
-Joel
ive gone through this twice on two different cars and i don't know the part number, but if you go to a chevy dealer and tell them what you need they will most likely find it. pull up a picture and just point it out. i did that twice and it works, give it a shot.
Yeah i figured thats what i would have to do, since i can't seem to find that part number anywhere. By the way when you have gone to the dealer have they had it in stock? Thanks
-Joel
-Joel
It looks to be the #14 i have the passenger one still on the car i need the drivers side, im assuming its the same part # or some part. Would i have to get the bolts as well?
-Joel
-Joel
I found this part number in the LS1 Owners - Newbies Tech section. The part number is 10407350 and is for Exhaust Muffler Hanger. The number works on GM parts Direct and shows up as a hanger, but theres no photo to confirm if thats what i need.
-Joel
-Joel
-Joel
-Joel
So is that number 17 on the picture above? I need the same one for my gmmg exhaust on my LT1
-Joel
-Joel
#14 in the picture above is 10275709
Whoever had the car before me used a hose clamp to compress the one on the pass. side and stuck a large bolt on the one on the drivers side to keep them from sagging. I don't know what's more 'ghetto', whoever actually put it on the car or me that doesn't actually fix it the right way.
