whats this mean
Originally Posted by bluenyghthawk
DTC P1153 HO2S Insufficient Switching Bank 2 Sensor 1
Originally Posted by staringback05
clear the code but dont worry about it if its a front o2 unless it starts acting bad....if it does its not going to hurt the car and you can change it no prob
If the code comes back after you clear it change the front O2 as soon as you can. Don't extend the wires by splicing them as there is usually a code thrown or it won't read properly because of something like the ohm resistance changes with extended wires and the dyno tune will then not read correctly. Just use extensions or buy the rear Vette O2's - Bosch 13111 and place them in the fwd bank they work very well......
