Looking for Shop in SE AZ
Hi was wondering if anyone could reccommend a good shop to go to somewhere in Arizona. I'm currently station about an hour southeast of tuscon but I'd be willing to go anywhere. The local dealership just scratched their heads at the problem I'm having.
Not much help in S.V. Most likely you will have to travel to Tucson or Phoenix. You could ask around at the car show tomorrow at the mall in S.V. You might get lucky and find some one who can help you.
CAV All The Way!!!
CAV All The Way!!!
I'm having alot of hesitation on acceleration and when I come to a stop it sometimes almost loses idle and dies. And from a stop sometimes it will have zero throttle response. So from a stop it will putter putter and as I give more gas it will eventually kick in and all of a sudden jump to life. But I never seem to have the amount of power it should have or did have.
Check the plugs, check for any intake leaks and whatnot...Clean the MAF with some carb cleaner...
Do you have any codes??? Any extra smell of gas??? When did this start happening, and is it all the time or just sometimes????
Try AZ power and Sound in Tempe, or NicD- he's a tuner, and this sounds like a bit of a tuning issue
Sounds like you may be new to the S.V. area. Have you considered the altitude difference of this area compared to where you were previously? We are at 4,800 feet.
I'm located near you so if you would like some assistance. I have the MAF and brake cleaner so you won't have to purchase any.
I was thinking the altitude might be doing it but I have a hard time believing it would have this much of an impact however I did come from the east coast which was basically sea level. Another strange thing is that I don't have any codes which I would think if its a tune problem it would have some sort of code. I'd appreciate any help you could offer and maybe an easy fix will do it. Its worth a try.
Altitude??? NO
I came from east coast, and my car did nothing...
I don't even know what S.V is...
if you be a little more specific, i can look it up on a map...
In retrospect, i live up towards Flagstaff, on I17...Wack *** neighborhood, but the money got real good and the rent is free...
