Sponsored by: DashLynx
Halo Headlights
Old 03-16-2007, 01:31 PM
99M6Z28's Avatar
Default Halo Headlights
I am getting some of the Halo Headlights for my camaro and I was looking for instructions on how to hook up the angel eye ring. I would like it run like a day time running light. Has anyone done this oe how is it done. What is the best way to hook them up?
Old 03-16-2007, 01:49 PM
Xx01CamaroZ28xX's Avatar
+1 I would like to know as well....
Old 03-16-2007, 04:30 PM
99M6Z28's Avatar
No one knows
Old 03-17-2007, 11:07 PM
Copy & Paste Moderator
VIP1's Avatar
You would have found the answer in a search:
https://ls1tech.com/forums/showpost....65&postcount=8
https://ls1tech.com/forums/appearance-detailing/454567-quick-halo-question.html
https://ls1tech.com/forums/appearance-detailing/445278-halo-owners-help-me-out-please.html
You can tap into the DRLs, side markers, or fog lights.
Old 03-17-2007, 11:31 PM
Swet thanks, I will probably splice em with my running lights.....Would that just make them run all day??
Old 03-17-2007, 11:54 PM
VIP1's Avatar
If you tap into the DRLs then they'd be on pretty much all the time.
I forget how the DRLs and front side markers are wired up on a Camaro. Are they the same thing or differnt bulbs?
Old 03-18-2007, 10:04 AM
99M6Z28's Avatar
Yeah, do the daytime running lights also act as your blinker or is there a seperate bulb because I really don't want the halo to blink when I use my blinker. Also, How do all you suys get pics of just your halos and fogs on at night. I cant do that because of the damn auto lights.
Old 03-18-2007, 05:25 PM
KILLER-LS1's Avatar
shine a flashlight on the light sensor on the dash and the headlights wont come on.
Old 03-18-2007, 06:01 PM
mikerulzu's Avatar
I wired mine up to the foglights. They're not really bright enough that you can see them when it's still light out, but it's nice that they light up when I unlock and lock my car.
Old 03-18-2007, 08:53 PM
Mistacamawo's Avatar
there is no point to wiring them to your DRLs, they arent visible during the day. the whole point of the halo it seems is to come on when you unlock your car or when your car is parked.
Old 03-18-2007, 09:00 PM
99M6Z28's Avatar
You do make a point there.
Old 03-18-2007, 09:25 PM
edwardswb's Avatar
I just wired mine with the fog lights so I can turn them off and on whenever I please.
Old 03-18-2007, 11:33 PM
Kage's Avatar
Cool
I have my Halos hooked up to daytime running/park/turn/alarm.
So they are being used all the time. FTW!!!
Old 03-18-2007, 11:44 PM
I dont like my fog lights tho lol.....Im gonna buy new ones eventually, but is definitely not next on my list. Is there a way I can have them on instead of my fogs?? Is it easy?? How would you do it??
Old 03-19-2007, 09:40 AM
Hugger Z's Avatar
If you start your car with the parking brake on, the headlights will not automatically turn on. You can then manually turn on your parking lights and if your Halos are spliced into those they will light up too. That is how I got my night pics of my halos. They are not noticeable once the auto headlights come on. But they look badass when hanging out in a parking lot when everyone's out cruising!
Old 03-19-2007, 02:47 PM
VIP1's Avatar
If the DRL is also the blinker, there are three wires: + for the bright filament, + for the dim filament, - for the common ground. I think you need to tap into the dim filament.
The auto-lights can be disabled if you use a scotch block (or another type of crimp) to short together the two wires going to the light sensor near the alarm LED. You can use a switch instead if you want to control when the auto-lights work.
Old 03-19-2007, 08:45 PM
99M6Z28's Avatar
I installed mine tonight and man they sure look nice. Hella lot better than my old oxidized stockers, and the halo looks sweet. I hooked them to the DRL's using a scotch block. Fairly easy install and I used the supplied mount. They fit great. One has a very little gap but it is hardly noticable so I just stuck with the supplied mount.
Kage, those bulbs are awesome!!!!! The brightest headlights I have ever had!!! I just hope they don't get too hot and melt my new headlight housings!
Thanks again!
Old 03-19-2007, 11:36 PM
So I take it, that its not possible??
Old 03-19-2007, 11:42 PM
Trunion King
bene's Avatar
Sure it's possible.. You can just get rid of the fogs and use the existing wires to make your halos work.
Old 03-20-2007, 10:56 AM
if you want to fix the gap you can put washers on the screws to close it up.
Quick Reply: Halo Headlights
