Swaping heads for FI will this work with my setup?
Old 03-16-2007, 10:42 PM
lasvegasgs's Avatar
Default Swaping heads for FI will this work with my setup?
Hey guys I have
TSP stage 1 heads now they are not milled.
I also have a Trqv2 cam 232/234 .595/.598 112
TSP sent me there hardned push rods I am not sure of the size.
Im going to get patriot stage 3 72cc heads with 2.08 1.60 valves and double springs.
Is there anything I need to change in order to run these heads? From what I understand they are not milled.
Also what should my comp ratio be with these heads Im planing on runing around 8psi.
Should I change my Cam now or Later to a boost cam.
Old 03-16-2007, 10:46 PM
navymitch12's Avatar
if you got the money then do the cam now.
as for the heads i am not sure but with 8psi you should be fine...my mind is kinda blanking out on what 72cc would give you for a comp ratio but with only 8psi as long as its not a smaller then stock cc then you should be fine
