Sponsored by: DashLynx
Which glue to use to reseal console lid cover?
Old 03-17-2007, 01:53 AM
kaos_'s Avatar
Default Which glue to use to reseal console lid cover?
The console lid cover on my console is coming off just a bit and I can see that it's held on by glue at the edges. What's a good glue to use that won't harm the material but still yield a tight bind?
Old 03-17-2007, 10:56 PM
Copy & Paste Moderator
VIP1's Avatar
Pics?
Its vinyl covered foam on a plastic or metal backer thats attached to a the hinge and there is an additional plastic cover under it. I've removed mine and recovered it in grey fabric. To remove it, remove the 4 or 6 screws holding the plastic cover under it. Then (I forget) either there are two more screws holding it to the hinge or two of the screws that were just removed also held the hinge. At this point the cover is now off and you can inspect it more closely.
Old 03-19-2007, 10:00 PM
VIP1's Avatar
Ttttt
Old 03-19-2007, 10:19 PM
wannafbody's Avatar
try SEAL ALL- you can find in with the oil and filters at WalMart
Quick Reply: Which glue to use to reseal console lid cover?
