sensors
sensors
My car has long tube headers and I'am on my second acdelco pass. side o2 sensor.My keeps throwing code 0155.The drivers side is good.I brought one bosch 13111 o2.Do you think I should install 2 new bosch sensors or leave the drivers side alone.The drivers side o2 is an acdelco & only has about 8000 miles on it.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Switch them around and see what happens. I had a set go bad, and it turned out it was just the passenger side. Try swapping sides and see if that fixes it. If not you might not be getting it hot enough. Try and carefully open up the vent holes a lil' more and try that as well.
