need help please, ASAP. Changed TB and now idling at 2500rpm
Old 03-17-2007, 02:51 PM
Ceissus's Avatar
Default need help please, ASAP. Changed TB and now idling at 2500rpm
Any suggestions?
I also sea foamed it, but i'm certain that my vacuum lines are reattached.
Should i adjust the screw that the throttle flapper actually lands on?
(by this i mean the spring loaded flapper, when closed, is stopped due to a little screw that it lands on)
did i do something wrong? i followed directions EXACTLY
Old 03-17-2007, 02:54 PM
Restricted User
WS6nJAX's Avatar
did you reset the tps?
Old 03-17-2007, 02:58 PM
Ceissus's Avatar
i wasn't aware that i had to
can you please tell me how?
edit: wait...to you mean pull the fuses and let sit for 5 minutes with keys out?
Old 03-17-2007, 03:03 PM
Restricted User
WS6nJAX's Avatar
i have always unplugged the tps, turn the key to the on position for a min or 2, turn the key off, plug the sensor back in and start it up.
Old 03-17-2007, 03:05 PM
Ceissus's Avatar
ok i will try this,
i'll be back in 5 minutes.
Thank you for responding
Old 03-17-2007, 03:13 PM
Ceissus's Avatar
WOOHOO!
thank you so much man....that fixed it(gonna take it for a test drive to make sure)
that scared me, thought i had a big problem....
Again, thanks!!
Old 03-17-2007, 03:35 PM
Ceissus's Avatar
nope, still doing it
there must be something else?
Old 03-17-2007, 03:45 PM
Ceissus's Avatar
help
Old 03-17-2007, 03:56 PM
Ceissus's Avatar
ttt...
Old 03-17-2007, 04:11 PM
02SS:ZEUS's Avatar
Try the screw. You should be able to adjust the idle just by screwing it in a little.
Old 03-17-2007, 04:15 PM
Bird-Of-Prey's Avatar
What TB did you put on? I hope it wasn't a FAST. Make sure that your throttle cable isn't too short for the new TB. They are adjustable.
Old 03-17-2007, 04:38 PM
Ceissus's Avatar
it's a P/P stocker from smokin87TA ...the sponsor that does em himself.
the cable isn't too short..
when i start it up it idles fine, but once i start driving it idles at 2-2.5k and only idles down when i come to a complete stop and then wait like 10-15 seconds
its terrible.
Old 03-17-2007, 05:22 PM
Restricted User
WS6nJAX's Avatar
make sure you didnt forget the o-ring when you swapped the iac sensor.
Old 03-17-2007, 07:58 PM
jimmypop13's Avatar
I just got my TB from smokin87TA today in the mail. I did the TPS reset at the same time I installed it and it has worked perfect all evening. I'm lovin it. It definitely picked up some power and the improved throttle response is great.
All I can think of is just to make sure there are no leaks & try the reset procedure below one more time. Just ignore step 3. It's what I followed and everything has been great. There was a red o-ring on the IAC sensor, make sure it's there too. I guess maybe the sensor could have gone bad somehow too. If you move around in your driveway with the hood up, can you duplicate the effect? Maybe you could have a friend check to see if the blade could be sticking open.
If you wanna mess with the idle set screw, here is the proper procedure. (thanks to predator-z)
1> Turn ignition off
2> unplug TPS sensor at TB (botom on driver side)
3> open the TB blade a bit via idle screw
4> Turn ignition on (do not crank)
5> wait 30 seconds
6> Turn ignition off
7> Plug TPS sensor back on
8> crank motor and see if it idles better
9> repeat untill idle is to your taste.
Old 03-17-2007, 10:18 PM
98Camarod's Avatar
I'm wondering if the blade isn't in right. When you had it off did you see if the blad would get stuck?
Old 03-17-2007, 10:30 PM
Ceissus's Avatar
it was a little sticky but i didn't think it would feel the way it does on the pedal.
Old 03-18-2007, 07:59 AM
98Camarod's Avatar
Take your lid and bellow off and get the screws out and line it up properly so it doesn't stick. It should move freely.
