224/224 .563/.563 114 Any results??
Old 03-17-2007, 05:59 PM
shamha0t's Avatar
Default 224/224 .563/.563 114 Any results??
Hi guys,
I've got 99-TR224/224-114 Thunder Racing Custom Camshaft - 224/224 .563/.563 114 LSA 1700-6600 RPM Power Band.
It is an LS1 with 59 cc Stage II Patriot heads. What rwhp should I expect? Any idea?
regards,
Old 03-17-2007, 06:39 PM
Blk97WS6's Avatar
Id say 420whp
Old 03-17-2007, 06:52 PM
Moderator
davered00ss's Avatar
I have the same cam and did 385rwhp cam only. You should see 420. I just bought AFR 205's and am waiting to install them. Post your results when you get them.
Old 03-17-2007, 07:02 PM
bigman's Avatar
Don't listen to these guys, you will see 419 rwhp. J/K
420 siunds about right, give or take. Thats a pretty stout and streetable setup you got there.
Old 03-17-2007, 07:58 PM
Thule's Avatar
hmm, with those stageII heads. 226/226/585 112lsa cam with fast90/90 i am told to expect rigt over 400, so 420 is a little to much with this cam?
Old 03-17-2007, 09:41 PM
john563's Avatar
Im an A4 with that cam and TSP stage 2.5 5.3l heads and put down 417rwhp 407ft,but i also have aported fast 90 set up.I hope this helps
Old 03-17-2007, 11:43 PM
shamha0t's Avatar
thank you ppl for your reply, today will say if I will go for that 224 or not
Old 03-18-2007, 05:43 AM
shamha0t's Avatar
One more Q
What the max lift on LS1 59cc? stock pistons
Old 03-18-2007, 08:17 AM
shamha0t's Avatar
Ttt
Old 03-18-2007, 08:31 AM
Moderator
I would call patriot on the P/V clearance on that.
Old 03-18-2007, 08:32 AM
Moderator
I know with my AFR's I can go to 61cc on 93 octane. I may only mill them to 62cc just to be safe. Your compression may be too high for pump gas on those heads.
Old 03-18-2007, 08:33 AM
Michael02hawk's Avatar
TR224-114 with AFR205's here. Results are in my signature line!
...but, a bigger cam is going in this winter.
Old 03-18-2007, 08:49 AM
shamha0t's Avatar
What was you lift?
Old 03-18-2007, 09:13 AM
PREDATOR-Z's Avatar
What is the relativeness of lift in this?
If it is for PTV, LIFT has practicaly nothing to do with PTV, max lift occurs at BDC not TDC where valve contact can happen.
Patriot 59cc LS6 "style" heads and that cam has more ptv than you can dream of.
Old 03-18-2007, 01:35 PM
Moderator
What about the compression on a 59cc head? Can that run on 93 octane fuel?
Old 03-18-2007, 02:49 PM
oange ss's Avatar
about 11.3:1, should be ok with 93 octane
Old 03-18-2007, 04:21 PM
Moderator
How is that if my AFR's are going to be 11.3:1 w. 62cc chamber or 11.47:1 with a 61cc chamber and a cometic .040 gasket?
Old 03-18-2007, 04:22 PM
Moderator
#'s I got are from Tony Mamo. I asked his advice about the heads with my cam.
Old 03-18-2007, 04:23 PM
'Trust''s Avatar
420 sounds right, you better! I made 400/380 with the same cam and my budget stage II 241's.
Old 03-18-2007, 04:54 PM
oange ss's Avatar
assumimg 59cc and .053 gasket
Quick Reply: 224/224 .563/.563 114 Any results??
