umi installed
umi installed
well installed the rear adjustable lower control arms, adjustable torque arm
and a4 cross member torque arm relocation. what a differance. much better fit than bmr because my other shop car is all bmr this on will be all umi time to order the complete front set up on monday
Do you think the the TA relocation made a difference? Thinking about getting it and wanted some real world input.
Also, when you say you are doing the front suspension, are you also doing the k-member? Are the motor mounts intergrated into it, or can you use any mount with it.
