don't know what to make of it
Old 03-17-2007, 08:35 PM
plaf713's Avatar
Default don't know what to make of it
i just had my 383 lt1 stroker done and to go along with my motor i went with a built 4l60e. i was driving the car to break it in and there was a horrible vibration, thought it was a u-joint but apparently the shaft in the transmission is moving, is my trans shot? it shifted perfected with no slips or anything, just a really bad vibration. input is needed. thanks
Old 03-17-2007, 08:37 PM
LS1Tech Sponsor
performabuilt's Avatar
what do you mean the shaft in your trans moving do you mean its moving in the tail housing ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-17-2007, 08:43 PM
plaf713's Avatar
im not an expert on transmissions, but its the shaft that goes into the driveshaft. i hope this helps
Old 03-17-2007, 08:46 PM
LS1Tech Sponsor
well it will move if the driveshaft is not in there its supported by the yoke on the drive shaft which in turn is supported by the tail housing bushing. Now if the yoke of the drive shaft is wobbling excessivly in the tail housing remove the tail housing and inspect the bushing in the tail .
__________________
Call 888-744-6542
Old 03-17-2007, 08:58 PM
plaf713's Avatar
i think i know what you mean, is it the 4 blot ending of it? im taking it to a tranny shop so do you think they will know whats wrong? do you think it will cost a lot to fix?
Old 03-17-2007, 09:04 PM
LS1Tech Sponsor
Im sure they will and it shouldnt cost much ,let me know what they find
__________________
Call 888-744-6542
Old 03-17-2007, 09:51 PM
plaf713's Avatar
will do thanks a ton
Old 03-18-2007, 10:33 AM
plaf713's Avatar
could the play be causing the shaking of the car?
Old 03-18-2007, 10:41 AM
LS1Tech Sponsor
well if theres alot yes for instance if the yoke is worn out or the bushing in the tail has excesive wear, But it could also be many other external issues also dealing with the drive train and drive shaft.
__________________
Call 888-744-6542
