Introductions & Greetings - I am part of the family
View Full Version : I am part of the family
00silverGTP
03-18-2007, 12:12 AM
well...I have been on the boards for awhile, but never posted. I have been awaiting the time when I could purchase a car. I decided on a 99 TA. Has a lid and slp catback. seems to run very well. Couple questoins, how much oil does it take? 5.5 quarts? The car has 80k miles, what general maintance should I do? Do these cars come with a amp or is this something the previous owner forgot about, its located behind the spare tire. One other thing.....my passenger turn signal dosent work and I have changed all the bulbs, is there something common about these cars I should know about? Thanks
Eric
Hot94Z28
03-19-2007, 11:28 AM
Welcome
ITSA6
03-19-2007, 04:24 PM
welcome and your owners manual should tell you how many quarts of oil you need if you didn't look there allready
sleepinghawk
03-19-2007, 04:45 PM
The 2002 transam I had, had the blinker problems every other weekend. My problem was that the bulbs were good, but the socket where the bulb sat was black and crappy looking. I cleaned the hell out of mine, getting the rust crud out of it, and then I got the contact that was needed. I was about to do the replacement when I decided to sell it. This helped me.
http://www.ls2.com/forums/showthread.php?s=&threadid=15143&highlight=turn+signal
Congrats on the transam!! Do yourself a favor when you get time, do a search on ls1tech and you would be amazed the info you can find to help you, Good luck :drive:
The Wreckoning
03-20-2007, 03:12 AM
welcome
00silverGTP
03-20-2007, 08:47 AM
thanks for the welcome. Trust me I have done a ton of research. I got the turn signal to work by cleaning the socket out real good. And the owners manual didn't come with my car, otherwise that would have been the first place I looked. From what I have read it takes 5.5 quarts, right? Well, time to start searching for the right exhaust set up.
Eric
Adam98Z
03-20-2007, 09:11 AM
True duals FTW!
Welcome, let's see some pics of the T/A and GTP please (would also like to know what's done to it since there are a lot of GTP owners here, including myself).
import_raper
03-20-2007, 09:25 AM
Yes 5.5 quarts with standard filter.
Camaroz
03-20-2007, 09:44 AM
5.5Qts but I put in 6Qts
sleepinghawk
03-21-2007, 05:30 AM
Eric
Try this for starters....I used this to help me.
http://www.ls1sounds.com/
I have the loudmoth 1, rumor has it that if your'e going with headers then the loudmouth 1 becomes to raspy. I have the loudmouth 1 and love it, I don't have headers. Good luck
Darth Z
03-22-2007, 11:10 PM
Welcome and congrats on the car!
CrashDan
03-22-2007, 11:25 PM
Welcome! I own a GTP also (if you still have one that is).
00silverGTP
03-27-2007, 12:16 PM
http://a203.ac-images.myspacecdn.com/images01/57/l_da951a22827e7b22d7f11c815e974742.jpg
http://a149.ac-images.myspacecdn.com/images01/37/l_178c36839bd86e9d0ef28f8a609ad934.jpg
http://a707.ac-images.myspacecdn.com/images01/6/l_698ed1389a6467653f7f4beee9e03582.jpg
2000 GTP with 3.4 pulley (supporting mods), CAI, and shift kit. The wifes car.
http://memimage.cardomain.net/member_images/6/web/582000-582999/582278_2.jpg
