Clutch bleeding techniques
Old 03-18-2007, 03:04 PM
SpdFrk1990's Avatar
Default Clutch bleeding techniques
Which one is the easiest and best do you think? Has anyone tried to push the fluid in through the reservoir with a pump? I have this bleeder and thought about doing it that way. http://www.sjdiscounttools.com/psv12-205.html
Would there be any issues bleeding the system that way?
Old 03-18-2007, 05:16 PM
brad8266's Avatar
aint worth 100$, its easy to just raise the car up and crack the bleeder while you have a friend push the pedal.
Old 03-18-2007, 05:17 PM
SpdFrk1990's Avatar
I alrdy have that bleeder so I would not be spending any extra.
Old 03-18-2007, 05:20 PM
brad8266's Avatar
Well in that case try it out then. I personally would just do it the old fashioned way though.
Old 03-19-2007, 08:03 PM
3.4camaro's Avatar
get a buddy in the car and tell him to push the pedal down.
then open the bleeder
then close the bleeder.
and that should be all you need to do.
Quick Reply: Clutch bleeding techniques
