How do you adjust Tial 50mm BOV??
Old 03-18-2007, 03:30 PM
ABeasst's Avatar
Default How do you adjust Tial 50mm BOV??
How do you adjust the Tial 50mm BOV. We want to make it tighter. Do you just install shims?
Old 03-18-2007, 03:37 PM
qqwqeqwrqwqtq's Avatar
Their are different springs available.
http://tialsport.com/documents/w3_tial_bov50_sp.pdf
Old 03-18-2007, 03:49 PM
2002ws-6's Avatar
Yes, you can add shims (washers) or change the spring. I pull 21" merc at hot idle so I got the 11psi spring. It would not snap open under low boost pulls and I'd get the rattle snake sound out of the turbo. I cut the spring about 1 and 3/4 coils up and put one hardend washer in the bottom. Now at hot idle I can just see the brown O-ring. Any throttle application and its fully shut and sealed.
Quick Reply: How do you adjust Tial 50mm BOV??
