69 Camaro, 5.3 oil pan, and wiring
Has anyone tried the 5.3L oil pan to see if it clears the steering linkage? Also, anyone have a preference of the painless wiring harness between the #60506 standard engine swap harness and the perfect rpm system? Thanks!
Not sure about the oil pan do you try a search? Have you looked at Speartech for your harness needs. I'm putting an ls1 in a 69 Camaro, just waiting for warm weather and cash. Good luck
The SEARCH button is your best friend, There's a sticky on this forum that sould help answer most if not all you questions. https://ls1tech.com/forums/showthrea...9&page=4&pp=20
