Breaking in turbo engine with turbo or without?
Ill be breaking it in on the street...should I break it in with the full 12psi..or start out with 4 and work my way up? I like the "moto" method..but it doesnt seem like it would be safe to break it in like that throwing 12psi at it. Any suggestions?
that is the only way you are going to make full power once it is broken is to let it feel the boost otherwise like 52172 said you will have excessive blow by problems...good luck with it
Hit it with 12psi off the bat?...I wont ruin the rings by throwing that much boost at it off the initial start up? I was told a bunch of different things like running with the turbo unhooked, or run 4psi for a few hundred THEN 12.. I know the moto method says to beat on it..which is why I was hesitant to throw 10psi as it off the bat. Anyone wanna explain in detail how they broke theirs in?
i am speaking from expeirience with diesels and the only way to seat the rings properly is to run the engine after initial cam break in at full throtle for a extended period of time on the dyno under load, if this is not done their you will have blow by issues and you will not make your full power potential but again i am speaking from a diesel standpoint so your best bet is to contact a well known turbo shop or something, hope that helps
Ive always been told to run it at the boost level the engine will be seeing. Like everyone else said becuase of blow by issues and to seat the rings. But best bet is to call a turbo specailty shop and ask.
so...set everything up how im going to run it..get it up and running right and then take it out (i have a 5 mile straight back road)..and just beat the **** out of it?
Originally Posted by SuperZ
i started off with the 5psi spring for the first hundred or so then worked my way up to 15ish.Its been fine for the last 2 years like that.
