Lid Question
Lid Question
Ok, Im installing a new whisper lid, only problem is that I cant get the MAF out of the old airbox. Is there a trick to doing this? I have tugged on it for a while now, and it has started to turn a little but it just wont come out.
Originally Posted by 00slowredz
did you take off everything up to the throttle body? mine came off pretty easy i just moved it side to side a few times and it popped out
I have been twisting and pulling this for a couple hours, and it has not even budged. I can only twist it about 2 degrees because of the anti twist key pieces on the MAF and airbox. I even had myself on the MAF and my buddy on the airbox and it still has not moved at all. it seemed a little more plyable under heat, but still wouldnt come out.
I think its going to meet the dremel tomorrow after I get home from work.. cause at this point Im sick of screwing with it. I did 4 sets of break pads in less time than I have played with the MAF sensor.. and I still have not taken the air sensor out either.
Mine took me a while to get out too, it wasn't budging. I ended up using a hair dryer like someone else stated in this thread, that got it considerably looser... that combined with LOTS of twisting eventually got it out.
