View Poll Results: which one?
LS7clutch w/LS2 flywheel
7
58.33%
SPEC 3+ w/LS1 flywheel
5
41.67%
Voters: 12. You may not vote on this poll
Clutch and Flywheel
Clutch and Flywheel
looking to do the SPEC 3+. Their website does not specify if you can use the stock LS1 flywheel. Has any installed the 3+ to there stock LS1 flywheels with success?
Also what would you do for a clutch that will see strip launches on drag radials? I am considering the LS7 with LS2 flywheel, or the SPEC 3+ with a resurfaced stock LS1 flywheel.
You can use the stock resurfaced flywheel provided it is surfaced right and 100% flat. I have the billet flywheel though and thats the way i would go if I had to do it again.
I would go with the spec 3+ for hard launches on drags.
Make sure that the flywheel is ground and not lathed. Also, after the resurface, lay a straight edge on it to insure flatness. Has you stock wheel be resurfaced before? If so then you may want to buy a new unit...there is nothing worse than going through the trouble of machining and installing a wheel that is too thin. Doing this would lead to slippage. Let me know if you have any further questions. Thanks,
