need some numbers (918s)
Old 03-19-2007, 09:31 AM
maybe2fast's Avatar
Default need some numbers (918s)
I have a hotcam want to do the 918 beehives. I need the numbers and good place to get them for the springs (918) and locks and retainers and anything else I need to install them on LT1 aluminum heads. thanks
Old 03-19-2007, 11:24 AM
Internet Mechanic
BlackScreaminMachine's Avatar
http://www.compperformancegroupstore...Category_Code=
HIGH PERFORMANCE GM LS1 VALVE SPRINGS
PART #26918-16
$238.88
STEEL RETAINER FOR 26915 & 26918 SPRINGS
PART #774-16
OR
TI RETAINER FOR 26915 & 26918 SPRINGS
PART #772-16
$312.48
As for the bottoms I am not sure, pm SStrokerAce
Old 03-19-2007, 11:25 AM
Internet Mechanic
FYI, you need NSA rockers, if you have the GMPP SA 1.6 rockers, they will hit the retainer. Look at Comp Cam Pro mag, 7/16" NSA rockers with a good guide plate, if you heads are not milled and not running a Morel lifter, 7.200" hardended pushrod.
Old 03-19-2007, 11:47 AM
maybe2fast's Avatar
wow, so SA rockers will not work with the 918... well I may just go with the LT4 springs.
Old 03-19-2007, 01:05 PM
rasputin's Avatar
is this true?
Old 03-19-2007, 01:13 PM
1997bird's Avatar
It depends on what brand of SA rocker arm that you have as to whether or not they will or will not hit the retainer.
Old 03-19-2007, 01:46 PM
Internet Mechanic
I have used them on my LT1, there was a issue, 1st hand exp, Bret converted my heads over personally, I had GMPP 1.6 rockers, swapped to Comp Cam Promags.
Nuff said.
Old 03-19-2007, 01:57 PM
1997bird's Avatar
Nuff said.
I have had the Comp rockers that were SA and they will work with these retainer's. Nuff said.
Old 03-19-2007, 04:46 PM
Internet Mechanic
Well thats well and good. So all post ill refer to you saying Comp Cam SA's work fine as long as you got the proper installed height of 1.800"
Running beehives meaning that he is running a decent cam, or some radical lobes, meaning having a NSA rocker is better for valvetrain stiffness and reliability in the upper rpms, so if he buys any rocker its prob going to be a comp cam, just NSA and be done with it.
If he is still running stamped rockers on the hotcam, then at least he doesnt have to rebuy stuff.
Old 03-20-2007, 10:42 AM
Imnotfast's Avatar
I run 918's with SA Promag's at the .600 lift and a installed HT of 1.900
Not a problem yet with any valvetrain.
Old 03-20-2007, 11:11 AM
Internet Mechanic
1.900" installed height!? A lil high there, any reason why, did you use shims?
Old 03-20-2007, 03:46 PM
maybe2fast's Avatar
I am putting in the hotcam and have some 1.6rrs from a hotcam kit but am looking for valvesprings and I thought 918 would be good for it. just need to find out if they will adapt well.
Old 03-20-2007, 04:37 PM
Imnotfast's Avatar
At 1.900 it has enough pressure seat pressure and open it can control the valve action and reduce friciton. In other words it make a little more power.
Quick Reply: need some numbers (918s)
