i believe i found a good deal for a t56 setup!!!!
Old 03-19-2007, 02:09 PM
z-boy's Avatar
Default i believe i found a good deal for a t56 setup!!!!
ok i found a lt1 6spd setup today for 800 dollars for everything...but i have a ls1 98z...i read to change the input shaft and front plate...how hard of a job is that?? will the clutch pedals out of a lt1 car work in my ls1 car???if i can make it work for a reasonable price i will try to get it.... any help would greatly be appreciated.....
Old 03-19-2007, 05:35 PM
Mike44138's Avatar
Just get an LS1 T56. By the time you buy the parts and mess with it you'd be better off. I can tell you from experience the input will run you around $300 alone, don't know about the front plate but I'm sure that's not cheap.
Old 03-23-2007, 12:37 PM
z-boy's Avatar
i herd that..im probably going to hold off and get me a built 4l60e
later...
