will a z28 exhaust fit a V6 camaro
Old 03-19-2007, 04:38 PM
LS1RedFbodZ's Avatar
Default will a z28 exhaust fit a V6 camaro
im planning on putting my magnaflows on soon and i have a buddy with a v6 camaro that i might sell it to..so i just wanted to know if my stock exhaust will fit onto a 98-02 3.8 camaro..
Old 03-19-2007, 04:44 PM
l337_haxs's Avatar
It should no problem with a little modification on the piping for him
Old 03-19-2007, 04:53 PM
98redM6's Avatar
More than likely it will fit no problem, but I think it's a waste of time if he doesn't replace the z28 muffler.
Old 03-19-2007, 05:30 PM
well were doin it mostly because his exhaust has a problem..im pretty sure from the muffler. i think an exhaust leak probably..but im not wiz at this so i offered him mine because i need to get rid of it anyways so i just wanted to make sure it would fit..
Old 03-19-2007, 06:44 PM
Starz T/A 17's Avatar
Yea both cars have the same 10 bolt, and same chassis so it should fit no problem... IF anything it might need a little modification where it connects to the Y pipe but that shouldnt be that bad
Old 03-19-2007, 07:32 PM
02silvaZ's Avatar
should work with a little persuasion
Old 03-19-2007, 07:35 PM
TheSecretFormula's Avatar
It should fit with some modification. Are you removing it yourself or is a shop doing it? If a shop is doing it they are going to want to cut it in the rear where it goes over the axle. If you don't cut it you have to let the panhard bar and stiffening brace down and I unbolt the rear shock from the axle to drop the axle enough to get the exhaust out. They will want to charge you extra for the job or if you do it yourself you will have some extra work.
Old 03-20-2007, 01:28 AM
ill be doin it myself..thanx everyone..
Old 03-20-2007, 01:58 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Yeah, If You can fit 4" you can fit stock on anything.
Old 03-20-2007, 02:30 AM
bww3588's Avatar
who in their right minds would put a 4 inch mufflex exhaust with a splitflow muffler on a car? you would have to be a total LS1tech.com moderator to do somthing like that......geez.
sorry Jordan, just busting your *****.
Old 03-20-2007, 08:18 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Note: You will also need to change to the V8 exhaust hangers in the rear. They are different than the V6 hangers. And the only thing you'll need to fabricate is the little "S pipe" section right after the cat that goes to the catback. They can be made for CHEAP or bought as well (SLP makes this kit and has everything you need to do the swap).
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Quick Reply: will a z28 exhaust fit a V6 camaro
