Northwest Members WA, OR, ID, MT, WY, SD, ND
Check out my A/F from the dyno pull.............
Old 03-19-2007, 09:27 PM
00Vette's Avatar
Default Check out my A/F from the dyno pull.............
I took just the A/F from the dyno graph and focused on that alone. Check out the attached graph and tell me what you think? I don't think that is good. From what I've heard, a lean spike happens with a wet kit. But check out how high it spikes? Kind of scary!! I'm not spraying anymore till I get this figured out.
I think I need to get a hold of TJ again and have him do some major tuning. Is this kind of spike normal for wet kits? That seems like an aweful high lean spike.
I need some major help!! Not the mental kind Ellis
Graphs:
http://i33.photobucket.com/albums/d5...e/DSC04331.jpg
http://i33.photobucket.com/albums/d5...e/DSC04330.jpg
Close up of the Graph:
http://i33.photobucket.com/albums/d5...e/DSC04328.jpg
Old 03-19-2007, 09:28 PM
Ryan'sSS's Avatar
Looks like you hate your pistons.
Old 03-19-2007, 09:31 PM
00Vette's Avatar
Any insight that actually may help me?
Old 03-19-2007, 09:50 PM
Ryan'sSS's Avatar
Upgrade your fuel pump yet?
I can all but tell you that Ellis will recommend having your N2O line twice as long as your fuel line.
Old 03-19-2007, 10:06 PM
00Vette's Avatar
I have the racetronix fuel pump and have over 60psi of fuel all the time. Ellis also recommended I get a shorter fuel line and longer N20 line. But with that big of a spike for that long, do you honestly think it will make a difference?
I mean........that spike in my inexperienced mind is disaterous! That's why I'm praying for some more experienced inputs.
Old 03-19-2007, 10:13 PM
Ryan'sSS's Avatar
Ellis's way seems to work really well for him. He has a puff of black smoke when his kit hits. Thats proof its on the rich side.
Russ went to a bigger fuel jet on his kit but he still has a lean spike when it hits.
Old 03-19-2007, 10:21 PM
00Vette's Avatar
True..........but the lean spike that Russ's car makes is way way shorter than mine. My spike is more of a curve. Russ's is just that..........a spike.
Old 03-19-2007, 10:47 PM
Rollin Black's Avatar
Hello Jon.
No expert here but I suggest you make the line changes for starters.
Some other suggestions:
Stand alone fuel system or switch over to a return system like Robert has.
Electric boost-a-pump to provide you with more fuel.
Timing tuner to pull back some timing at the top end.
Thanks, Perry
Old 03-19-2007, 10:59 PM
Ryan'sSS's Avatar
Russ had the same problem as you and then went to the bigger jet and that helped all but the inital spike.
I wouldn't spray that again until you get that fixed.
Old 03-19-2007, 11:01 PM
NVME's Avatar
Make that nitrous line longer like Perry said. I have a stand alone fuel system I will let go crazy cheap, Jon! PM me for my number if you're interested.
Old 03-19-2007, 11:11 PM
00Vette's Avatar
PM sent.
Old 03-19-2007, 11:38 PM
NVME's Avatar
Back at ya.
Old 03-19-2007, 11:49 PM
Robert56's Avatar
The vette takes a special stand alone, and the only one who makes it is Nitro Dave, and he also has one, at my request, for guys running the Vararam. I will be using his Vararam tank for my stand alone system for dry users I am putting together.
Fuel problem, my take, same as last year (remember running 10.x:1 a/f with the same lean condition in the begining), fuel supply problem ie: as Perry said, return and reg at the rails. However, as everyone stated try the line lenghts first, it can help to minimise and sometimes eliminate intitial leaness. But i still say supply can't keep up for a minute then recovers and that's different from a lean spike. Or you could go dry and have no lean spike.
Robert
Old 03-20-2007, 12:22 AM
00Vette's Avatar
Robert
Yeah, but look at my A/F graph closely. Its lean for a long time. Is that normal for a "lean spike"?
Old 03-20-2007, 01:12 AM
KrautBurner's Avatar
yeah,
mine was huge with the "100 jets"
I jetted up to the 150hp fuel jet
and still have a "spike"
will have ellis make me a longer line next time the car is in
Old 03-20-2007, 02:29 AM
Ryan'sSS's Avatar
Yeah I hope DR Ellis fixes mine as well.
Old 03-20-2007, 07:14 AM
01Z28M6's Avatar
I have a dedicated set-up button that pushes fuel only to the nozzle before I spray. In other words, I purge the air out of my fuel supply. I don't have any hard readings on the effect other than a way to watch for knock but I do have the assurance that gas is ready at the nozzle the moment the nitrous solenoid opens. I always worried about an empty fuel line lagging behind the nitrous.
Old 03-20-2007, 09:39 AM
TwoFast4Lv's Avatar
I would start with fuel line lengths. You may also need a fuel accumulator.
Before we started playing with mine I was getting a 16:1 lean spike. Now I get a 10:1 Rich spike and that is how I like it After the hit she leans up to my normal 11.0 to 11.2 from 4,000 to 7,200
Old 03-20-2007, 10:57 AM
00Vette's Avatar
Okay, I'll do that first. What is a fuel accumulator, what does it do, and where can I find one?
Thanks Ellis.
Old 03-20-2007, 12:06 PM
nx makes an accumulator,
it's kind of like a capacitor for a car stereo (but for fuel)
