How to remove tough overspray
I got some silver overspray on the car due to a gust of wind that came out of nowhere. I've tried a claybar and it won't take it off. I've got a buddy that can buff pretty damn good and he says he can get it off. Any other suggestions?
Hold on there. That should NOT be used. The picture is 3M Perfect it II rubbing, that is a medium cut. That on a buffer will swirl his car all up and make more problems. Do NOT use that. Try nail polish remover or some lacquer thinner first. Nail polish remover should remove it no problem. If it's on the glass use some 0000steel wool to clean it off the glass.
O OK well thats what ive seen used a bunch to detail cars with and then follow with a 3m polish with a polishing pad. not for sure bout the perfect it part i just know that we used the 3m rubbing compound followed by the polish. All using the buffer to do it, and the outcomes have been great. But we did water sand the car first also (shrug)
Nail polish remover is ACETONE. This WILL harm your factory finish. Lacquer thinner however takes a long time for it to even start to damage factory urethane paint, and will quickly soften spray paint (most of the time is lacquer based). I completely removed a painted on pinstripe on my Olds with lacquer thinner, and the original paint was untouched.
clay bar is the safest way to get it off .. personally I would work the clay for a bit before I tried anything else ..
there are several things to try prior to buffing it with a mediumj cut compound ..
have any plastic razor blades ?
also, prior to the buffing, you could try some scratch-X, or Meg's #2 both can be used by hand ..
Originally Posted by jargan04
Who told you acetone will hurt paint? I'm a professional detailer and use acetone all the time. Lacquer thinner will start to eat into the paint before acetone ever will.
Thanks for the help!
What method do you use with acetone? I watched someone mess their factory paint up with it once, trying to remove a scuff mark on a painted bumper. Paint softened and went "dull", went thru the clearcoat and the color showed on his rag. Since I've seen that, I haven't ever chanced it.
clay bar or laquer thinner, should do the trick no problem, dont get into rubbing compounds unless all else fails.. DESTROYS paint if not used in the smallest amounts
