Manifold bolts...
Old 03-20-2007, 12:14 AM
93BlackZ28's Avatar
Default Manifold bolts...
What is the best way to get the stock manifold bolts off? Has anyone had a problem with them braking?
Old 03-20-2007, 12:36 AM
LiENUS's Avatar
Put them on my car, two of them backed out on their own on my manifold! they weren't even finger tight!!
Old 03-20-2007, 01:34 AM
95FbFormula's Avatar
I took all of them off my 95 with no problems at all. I guess it just depends but for insurance you use some liquid wrench or similar. Take make sure you take your time if they don't feel like there going to give don't force it
Old 03-20-2007, 08:44 AM
93BlackZ28's Avatar
to the top
Old 03-20-2007, 09:28 AM
Internet Mechanic
BlackScreaminMachine's Avatar
intake or exhaust?
I assume the exhaust, I have seen them break. My LS1's with 32k 5yr on the bolts were tight as ****, they didnt break but you gotta watch it.
Old 03-20-2007, 09:30 AM
Temple's Avatar
Just take your time and hopefully you won't run into what I did. All of mine backed out very easy except the driver's side rear bolt. It was like it was heat welded on and deformed to were I couldn't get a good bite on it. I had to grind of the head of the bolt then slide the manifold off the remaining bolt. Then I was able to back the bolt out with a stud puller. Main thing...don't bust a bolt off in the head!
Old 03-20-2007, 09:39 AM
Temple's Avatar
pics for my previous post
Attached Thumbnails Manifold bolts...-dsc00526.jpg   Manifold bolts...-stock-manifold-bolt.jpg   Manifold bolts...-stud-puller.jpg
Quick Reply: Manifold bolts...
