LT1 Solenoid Brackets
Old 03-20-2007, 10:04 AM
Chris@NitroDaves
Guest
Posts: n/a
Default LT1 Solenoid Brackets
Ok Guys we have two designs for you to choose from.
This solenoid bracket will mount off the top of the throttle body bolts. This unit will clear a stock hood with a little " finesse " you will have to either bend the bracket a little or clearence the hood bracing.
This solenoid bracket will bolt down using the front two fuel rail bolts.
If you are using a purge port design solenoid the bracket has enough room to mount the purge and gives enough room for the fuel and purge hook ups.Both units are instock and are ready to ship. They are currently not on the website but will be on there shortly. You can call you order in
( 1-866-648-7637 )
Thanks
-Chris
Old 03-20-2007, 10:07 AM
Tony Shepherd's Avatar
Wow! Very nice guys! Its about time someone steps up and makes brackets for the ol forgotten LT1.
Old 03-20-2007, 10:13 AM
Bad Dad's Avatar
Prices?
Look like nice parts!
Old 03-20-2007, 10:31 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
They will sell for $36.75
Quick Reply: LT1 Solenoid Brackets
