Which O2's to use?
Which O2's to use?
Do i use the sensors off the manifolds or off the cat and lower y-pipe which have square plugs? What will i need to do with the plugs that used to connect into the manifolds, can i just leave em?
good to know.....how should i route the extensions so they dont rub the ground or hit the headers? Can i zip-tie them to the transmission or will the tranny get to hot?
