another whatdo you think she"ll do thread
Old 03-20-2007, 03:02 PM
spcearle's Avatar
Default another whatdo you think she"ll do thread
i know i wont know till i dyno and take her down the strip but wondering what you guys think it might do
383//lt4 afr 195s reworked a lil/custom grnd 236-242 110 lsa/1.6 crane golds/lt4 intake matched to heads/58tb/30lb inj/ltcc/2800 stahl stage3 a4/342 gears/somewhat sticky streets/adj rear suspension minus torque arm/lts goin into lm cat back......about 3700 lb weight with me
Old 03-20-2007, 03:20 PM
streetwarrior96's Avatar
you should be where I am at. My specs are on the link
Old 03-20-2007, 03:36 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
you are going to want more stall...2800 is a little small for a 236/242 duration cam
probably gonna want to be in the ~3500 range
Old 03-20-2007, 04:42 PM
spcearle's Avatar
was your run with or without nitrous...just wondering tryin to figure here i have a lil more cam and more lift and that would make up a lil diff between my a4 and your m6
i know i need a lil more stahl...when i did my tranny it was for a bolt on with a hotcam...now it is a stroker with a bigger one but correct me if i'm wrong a stroker makes stahl seem higher and my mottor is built more on a torque side versus hp so it should better keep me in my powerband with a smaller stahl
Old 03-20-2007, 04:52 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
My times
11.6's w/a 222/228 cam NA and 10.9 on a 150 shot
11.3's w/a 248/254 NA and 10.4 on 150 shot
the same convertor behind a more powerfull motor will have a slightly higher stall speed.
But for the best results you will want to get that one restalled or replaced altogether depending on the convertor
Old 03-20-2007, 08:39 PM
97blkz's Avatar
I agree on the stall being too small. I have a 3200 vig and the car went 11.68 @115 N/A. Car is designed around spray. Car went 10.43 on a 150 shot. Stall flashes at 3800'ish on spray.
Quick Reply: another whatdo you think she"ll do thread
