Th-350???
Th-350???
Just got my th-350 rebuild on first turn on.Tranny fluid went all over the place so thinking it was tranny pan gasket was done twice.On 3rd turn on I took better look i notice leak was coming from servo my question is what could i do replace servo.
I know there tool to take off servo, what would be best one too use(servo)? Damn i hate transmission..
The cover on the side is an accumulator, they probably used a B&M **** kit, yes **** kit. It says to leave the spring out but when you do that it doesn't push the cover on enough to seal it. I'd put the spring back in with a new o-ring and run it like that or put a 1 1/8" x 5/16" pin in the hole under the plug near the accumulator to block fluid flow to it.
You need no special tool to remove the cover, tap it in and insert a long 1/8" allen wrench or pin, awl, etc into the small hole in the case on the other side of the retaining ring, this will push the ring out enough to grab it with needle nose pliers.
But chances are real good it's really leaking from the detent cable or dipstick.
Thanks for help guys should be getting this done later on today...Lines,dipstick had been check it damn circle next to lines which was told its called servo, ill be done an see track on friday..
